Fitting Wipers For Mot
  • Please log in to reply
12 replies to this topic
#1 Jonnyround2003
Jonnyround2003
    Wheely good builder!
  • Community user
  • 380 posts
  • Car type:Robin hood 2b
Posted 02 October 2017 - 08:55 PM
Anyone got any pics on fitting wipers and screen washers my car failed mot as I have a screen but nothing else anyone else had this problem
#2 florin metal works
florin metal works
    Hants & Dorset Area Secretary
  • Area Secretary
  • PipPipPipPipPip
  • 7,830 posts
  • Car type:2B+
Posted 02 October 2017 - 10:05 PM
If you have been running with-out wipers/washers you are very lucky to get away with-out being pulled by plod --- or worse --- involving some other innocent in your accident due to not being able to see. You deserve to be beaten with a stick of soggy rhubarb!!
On the plus side -- obtain a mini wiper motor & gear ( must be 2 speed ) & any style/make of washer & fit ---- quickly.
#3 kevin the chicken
kevin the chicken
  • RHOCaR 18
  • 951 posts
  • Car type:16v vauxhall series 7, Sylva Leader with Pinto
Posted 03 October 2017 - 06:27 AM
You could fit an aero screen and Wear a helmet which is what some people do to get through the sva test. I presume this is what has been done to your car. That way you wouldn't have to worry about washers and wipers. Personally I found it windy enough as it is with a full screen so I would follow florins advice. My rhubarb seems to be a bit lack lustre this year so you are safe from me!
#4 nelmo
nelmo
    Magazine Editor
  • Committee
  • 820 posts
  • Car type:GBS Zero
Posted 03 October 2017 - 07:55 AM
I've got some details in my blog:
https://zerolifebuil...ch/label/Wipers
Not great - glossed over it a bit...I bought this wiper kit from CBS:
https://www.carbuild...creen-wiper-kit
#5 Jonnyround2003
Jonnyround2003
  • Community user
  • 380 posts
Posted 03 October 2017 - 04:52 PM
Iv only ever driven the car in the summer so no need for them florin
#6 nelmo
nelmo
    Magazine Editor
  • Committee
  • 820 posts
  • Car type:GBS Zero
Posted 03 October 2017 - 05:53 PM
Yeah, 'Cos it never rains in summer in England ;-)
#7 florin metal works
florin metal works
  • Area Secretary
  • PipPipPipPipPip
  • 7,830 posts
  • Car type:2B+
Posted 04 October 2017 - 07:00 PM
Don't think we should be encouraging avoidance action on such a safety critical item, Richard.  If he decided to run with a screen & no wipers after IVA its likely screen would go back after an MOT; though the test station may ( hopefully ) refuse a pass.
#8 nelmo
nelmo
    Magazine Editor
  • Committee
  • 820 posts
  • Car type:GBS Zero
Posted 04 October 2017 - 07:57 PM
I have to admit, I don't normally like nanny-state interference but having a windscreen without wipers is dodgy. I got caught in the rain a few weeks ago (started out a sunny day with no rain forecast) and my wipers weren't working - I had 20 very tricky miles peering round the screen to see ahead.
I always assumed the wind blast would blow the water off the screen but it doesn't at all.
#9 AndyW
AndyW
  • RHOCaR 18
  • 258 posts
  • Car type:Robin Hood Super Spec, Rover 2L DOHC
Posted 04 October 2017 - 09:18 PM
It does if you use Rain-X on the screen :-) Ive driven several miles in pouring rain in my Superspec and found I rarely needed to use my wipers at speed. Air speed does keep the screen pretty clear.
RH Super Spec, Rover 2L DOHC, yellow grp, built & registered 2009, 2nd owner
#10 agent_zed
agent_zed
  • Community user
  • 2,919 posts
  • Car type:2B with double wishbones
Posted 06 October 2017 - 08:25 AM
i modified he original sierra setup but it was a bit of work as i had to change the pivot point of the one arm to adjust the sweep. The mini system seems a simpler way to go.
The other thing i did which you may want to do is make short wiper blades. I used the new single piece type wiper and cut them down to 6inches. They work pretty well. I used ones for the front windscreen but i have seen on modern cars that they do a smaller version for the rear windscreen which may be even better as the springing won't be as strong.
I used my sierra wiper arms cut down and welded the U shape on so i can use normal fittings rather than having to screw it on etc. That way i can carry a spare that i can easily swap if needed.
I've had to commute for the past month in my 2b as my normal car is out of action. So my wipers have come into use quite a few times. They are well worth it and as said above a must have safety item. You are in a tiny little car without ABS, traction control, DSC, air bags and sip so anything you can do to stay safe is worth doing.
Just be add another thing into the mix is your windscreen laminated? i suspect not as mine isn't it's just toughened. If it breaks you will get showered in glass although it shouldn't be sharp. I ALWAYS wear sunglasses or clear safety specs but i am going to put some of the antishatter plastic film on the inside to hold it together in an accident. Its only about £5-10
hth
#11 Smig380
Smig380
    Getting there Builder
  • RHOCaR 18
  • 50 posts
  • Car type:GBS Zero 2l Pinto
Posted 07 October 2017 - 12:19 PM
I put a screen and wipers on a couple of years ago. Went for mini system on eBay as GBS were a bit pricey. It wasn't a quick job, hints on this blog were very helpful but beware your screen position may be unique to your car so there's a lot of trial and error positioning the wipers themselves and they had to be cut to size. Used a basic CBS washer bottle kit which was the easier part, but measure up your space for the bottle first as there are size options. The elation at getting an MOT pass was pathetically worth it though, best of luck !
If you opt to remove screen for a quick hit MOT don't forget to mount your wing mirrors somewhere.
#12 Smig380
Smig380
  • RHOCaR 18
  • 50 posts
Posted 07 October 2017 - 12:51 PM
#13 nicko
nicko
  • RHOCaR 18
  • 1,349 posts
  • Car type:2B Plus, 2.0i
Posted 07 October 2017 - 05:15 PM
Just as a side note, I used an aluminium drinks bottle with a washer motor fitted to the bottom, been ok for over 10 years and passed every MOT.
Nick
2.0i 2B Plus. Collected 30/10/04, SVA passed 24/05/07, GRIN factor...... off the scale
Posted ImagePosted Image
