Mice In My Coilovers
  • Please log in to reply
8 replies to this topic
#1 Ant
Ant
    Wheely good builder!
  • Community user
  • 1,331 posts
  • Car type:2B, 2.0EFi, All stainless, Front wishbones (Now sold)
Posted 19 June 2003 - 10:09 AM
Wow - my first post in the "driving" forum.  An achievement or what!
Right then drivers ... I have RHE coilovers all round, and every time I hit a pot hole or go over a speed bump I get an eeek eeek squeeky noise.  If I hold the springs still in my hands whilst someone else bounces the car then it stops.  Any suggestions?
Is it the springs on the seats or is the the springs on the shocks inside?  If it's the seats then I'll make up some plastic washers for either end, but if it's the spring on the shocks then it's a bit more awkward.
Someone suggested spray grease, but I don't fancy that.  The car is pretty clean, so I don't really want greasy springs and dirt clinging to them.
Ideas please.
Ant
Ant Allen, Burton on Trent, Staffs
RH 2B, Wishbone setup, Stainless chassis & panels, Blue GRP, EFi engine.
Collection: Aug 2002
SVA: June 2003 at Derby
Sold: Nov 2004
www: www.nottingham.ac.uk/~eazaja/kit_car
#2 Andy Sparrow
Andy Sparrow
    Getting there Builder
  • Community user
  • 95 posts
  • Car type:Series III NOW SOLD
Posted 19 June 2003 - 11:06 AM
Ant
mine (at the rear) have squeaked since new, I ve tried various cures most of which only last for a few weeks, the easiest silencing method Ive found to be spraying WD40 or similar onto the shocker shiny stem not the springs, this lasts for about 2 months and doesnt, seem to attract any dirt.
I suppose we could experiment with a thicker oil but I m not sure what the longer term solution really is .....
A
[URL=http://www.asnw18630.pwp.blueyonder.co.uk
#3 Joel
Joel
    Mister Hard Top
  • Community user
  • 1,351 posts
  • Car type:2B, 2136cc Pinto, MegaSquirt & CBR Throttle Bodies
Posted 19 June 2003 - 01:08 PM
I'd appreciate any solutions on this one too. I've not driven the car in anger yet, but I can tell the rear springs are going to squeek like hell.
I didn't know if spraying certain lubricants on to the stem of the shock could damage the oil seal?
#4 Les Welsher
Les Welsher
    Mr Wales 2012
  • Full Member
  • 1,124 posts
  • Car type:2B wishbones DOHC
Posted 19 June 2003 - 03:53 PM
I took my car out for a drive on Tuesday, managed to get the wife in it for the first time :D .  After a 30 mile run I was driving around a car park very slowly looking for a space and noticed my front wishbone suspension was squeeking like mad, I hadn't noticed it before and you can't hear it when driving as the exhaust is so noisy.
I have sprayed lubricant on the shocker rod but the noise is still there. I thought it could be the bushes in the wishbones but if it happens on the rears then maybe not.
I have the sierra springs and shocks on the back and have no problems with them.
Ant, is the noise on yours from front or back ?
Les
2B wishbone, newly fitted RS2000 2L DOHC 16V engine, 1989 DOHC donor.
On the road since March 2003
Newport, South Wales
My Web site
#5 Ant
Ant
  • Community user
  • 1,331 posts
Posted 20 June 2003 - 01:01 PM
Both, but most noticable at the back.
I know this because if I jump on the chassis at the front then the front ones squeek, and if I stand on the spare wheel carrier then the back end squeeks too.
The back is more noticable when driving, particularly over speed bumps.
I've still not got a good solution to this.  I need to investigate, but it won't happen until next weekend as I'm going to York tonight (in the 2B) and then planning to come to Newark on Sunday.
Ant
Sold: Nov 2004
#6 Daz
Daz
  • Community user
  • 122 posts
  • Car type:2B
Posted 20 June 2003 - 09:43 PM
I had the same for quite some time.  It was driving me crackers.  It started on one corner and seemed to spread all round the car.  Eventually I tracked it down to the plastic coating on the spring squeaking on the metal shock absorber as it is so tight a fit in there.  I put a light coating of grease onto the shocks and springs about a year ago now, and have not had a peep out of them since.  Yes, they attract a bit of dust, but it is much better than driving through a busy town centre and having everyone sniggering at your squeaky car as it passes by.
Daz
#7 GTO
GTO
    Builder
  • Community user
  • 16 posts
  • Car type:sub k
Posted 21 June 2003 - 01:00 AM
just an idea and its worked for me in the past!
put some heat shrink around the last few inches of each spring (it needs to be a quality heat shrink not the halfords stuff)
this stops it making a noise on the seats and helps to give the spring clearance in the middle
there is a company called Raychem that sell some heatshrink called DR25 its the stuff we used
ive got some left if you are local you are more than welcome to take some
may not work but it looks neat and its gota be worth a try
#8 jwaterman
jwaterman
  • Community user
  • 69 posts
  • Car type:2B+ st/steel body & Chassis, 2.1 160BHP (completed 1st April 2003)
Posted 11 July 2003 - 10:33 AM
I had the same problems with my units front and rear. The rear was worst.  I found that the bottom mounts had turned slightly and the bush centre line was not parallel with the trailing arm pivots.  Moved them bach and secured. noise stopped. but then decided to change units for gaz ones.  far superior ride and handling.  Just done 3000 miles in europe with out any problems with suspenssion.  Only had the alternator bearings go.  everything else was fine.  Didn't use a drop of oil or water throughout trip.  Car drove very well on the Austrian / swiss high Alpine passes. Welsh hill climb hear i come!!
all best
john
You'll never know unless you try.
#9 ColinR
ColinR
  • Community user
  • 119 posts
  • Car type:Sub K
Posted 11 July 2003 - 12:36 PM
I fixed a mate's Granada squeak with silicon spray.  It took a couple of days to pentrate properly, but then he had no more trouble.  I don't think it attracted crap either.
Don't question Authority - they don't have a clue either!
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
