L/w Strengthening
Guest ScotMac
  • 7 months later...
  • Replies 83
Guest ScotMac
My promised update to how my l/w strengthening is progressing (topic has taken greater importance in the last couple of months! ;) ).
Will try to get some photos out soon, but in general, they don't show much, since most of the stengthening is integrated into or replacements for the RH supplied pieces.
In general, i have:
1. Completely modified the diff box and rear suspension boxes, by adding a very thick plate (3/16") along the diff box sides and adding angled pieces to every one of the corners of the 15x sections. All are bolted and bonded in place.
2. I have added 2" x 1.5" boxed aluminum the *entire* length of the rolled over top box section on the side of the chassis. Note, the 1.5" fits perfectly into the chassis top. Used 2 sections, one 60" for the front, and one 40" for the passenger area. The pieces are bolted and glued into place (zinc coated strength rated (8.8) bolts). Note, the back of foot well panels have to be cut where they wrap around the top of the chassis side to allow these box sections to be slid into place, along w/ the fact that the rivetting on chassis top is all replaced w/ bolting, where it matches up w/ the new box sections (outside rivets).
3. Replaced the "layered" pieces of aluminum in the engine bay floor sides and the engine bay floor nose area w/ 1/4" thick (!!!) peices of flat aluminum, thoroughly bonded and strength bolted in place.
4. Replaced the angled pieces, used to connect the front lower box sections to the engine bay floor, w/ angled steel pieces (w/ cut-outs for lightness, and zinc coated and fully glued to ensure no corrosion).
5. The forward front-top box section is bolted to the new chassis top box section.
The box section bolting utilizes Graham's tubular section insert idea to ensure no squashed box sections. ie, overdrill one side, insert the tubular section all the thru the box, up against the non-overdrilled side, and washer both sides to lock it in place.
Todo:
6. Replace the 28x sections w/ 3/16" thick plate aluminum, adding a large solid piece of aluminum at the top to handle the fact that the top box is offset from the bottom box by about 3/4".
7. Stengthening plates for seat belt mounts (see if can hook them into other strengthened areas).
8. Add transverse box sections to the bottom of the chassis, tying them into lower box sections in the passenger bay, and use vertical box sections to tie them into the new top of chassis box sections. Note, this may be overkill, but is probably necessary to get it past the safety marshals when i try to race the l/w.
9. Add an extra plate under the rollbar (from Marcus and others).
All the bonding uses the Fusor 112b automotive glue i have detailed previously.
All the new aluminum is 6061-T6.
Hope this helps, and for the lw'ers that are going, have fun at the f2f!
Cheers, -sm
Guest warwick7735
Scot
900lbs, blimey thats only 409kgs some 200kgs lighter than mine. I know the pinto is about 60kg heavier than what your using, so how have you saved the other 140kg.
Those tiny holes in the body are for rivets, not for weight loss :p :p
I'll eat my rivet gun if you can get it to weigh 900lbs. :lol:
Warwick
Guest ScotMac
Scot
Warwick
:D :D :D You had better get some really strong teeth...i hear rivet guns can do major damage!!
Didn't i tell you that i got in my raceleda sierra replacement aluminum upright kit? Not only is it *gorgeous* ;) , it also shaves about 17lbs a front corner. Also, what about engine auxilliaries? hmmm...let me see:
ITBs vs. carbs and carb manifold?
ultra lightened flywheel
t5 vs type-9 (?? might be about the same)
windshield vs aeroscreen
lightweight carbon fiber seats
lw scorpion racing motorcycle exhaust (maybe a bit loud!!! ;-) )
rear disc vs drums (???)
aluminum shocks on all corners vs zimmers
I think i will get it under 1000lbs...ok, so call the 900lbs a *goal*...w/ the rivet gun munching incentive!!! ;)
With respect, I'd be shocked and suprised if you can hit 900lbs ScotMac, a tricked out bike engined westfield is about 400kgs!!
My lightweight weighed in at 590kgs with a Zetec engine in it.
regards
Simon
Guest ScotMac
I did say it is a goal!! ;)
I have also seen BECs weighing in around 400-450kg. I saw a comparison of a hayabusa (one of the best bike engines) to a zetec, that showed the zetec about 80lbs heavier and a duratec is lighter than a zetec.
Also, remember i don't have pass SVA. My car, at least initially, will be very stark. Not much more than the minimal parts necessary to make it roadworthy and get it past the CHP inspection (lights and brakes inspection) and DMV.
Guest ScotMac
Scotmac thanks for the posting, its given me lots of ideas on what to do :D
Marcus
Great. In fact, I firmly believe all the strengthening i have done, plus the proposed roll bar and seat belt mods, would be enough to get a l/w past the chassis strength SVA inspector concerns.
Cheers, -sm :)
  • 2 months later...
hi
my weights for the test were 310 front and 300 rear i dont know how that relates to total weight in kgs.
i think a good split weight though.
my lightweight will never be a true lightweight though as the material to make it stronger has signifiquentley added to the overall weight.
scott you have used some exotic materials to keep weight down ,ie alloy front upwrights ect.
the tester commented that the car was verey light though.
my impression is that the car weighs arround 750 kgs.
i may be wrong and if lighter i would be happier.
ie 750 *2.2 =1100lbs
seems heavy to me?
a 2b weighs less than this.
how to calulate the total weight without putting it on a weigh bridge??????????
regards graham
Guest ScotMac
hi
seems heavy to me?
regards graham
I believe locostbuilders have the answer to that question...i'll take a look and get back shortly (unless someone beats me to it!!! ;-) ).
Guest ScotMac
Here is a good discussion of it (sva weights):
http://community.rhocar.org/index.php?showtopic=7811
It appears (from that thread) you can take off about 50 to 80kg's from the added sva weights. So that puts you at about 300 + 310 - 80 = 530kg * 2.2 = 1160lbs. That's actually pretty good!! Congrats! :)
BTW, i agree, your weight distribution is quite good. I still have not heard one peep from a l/w owner in terms of how the car handles!!! Graham?
Guess i'll have to finish mine to find out!!! ;)
Getting confused now, although I do know for definite that adding together the weight
over the two axles measured separately equals the total weight of the car - You can prove this
with a bit of A-level Physics (moments and forces). ;)
So, are the axle weights people are talking about a] measured on scales at SVA or b] some
sort of estimate of maximum capacity? The only way that a weighbridge can give a different
weight for the total car is if either the weighbridge or the SVA scales are out of calibration!
Pete :D
