Rear Suspension Problems
Guest tom2b
Guest Gpayne
hi tom you say you have fitted front springs i had the same problem while i was building mine i had fitted the front springs instead of the rear springs which are slightly wider and catch the drive shafts got some rear springs from someone who was fitting coilovers and had no problem if you want something harder fit granada rear springs graham
  • Replies 36
Guest Gpayne
you might be right ! but changing to rear springs did the trick for me been on the road for a year now only bottomed out once but 60 over humped bridge will do that. i think the front spring distorts under load catching the drive shafts i had the same scrapes as you. graham
Guest tom2b
So graham was your problem just bottoming out or catching the driveshafts and bottoming out like mine? So i take it the granada rear springs fit in to the sierra spring cups with out any problems? If so ill get hold of a pair and give them a go. Im also buying some rear coilovers off of another member while they are available as my back up plan.
Guest Battery Bill
I seem to remember you should use the Fronts off the Sierra, But Im not that sure.
The ones on our 2b2 did not seem to be front or rears but they still hit the driveshafts :rolleyes: :D
Guest tom2b
ah well if i cant cure it with springs i will use the coilovers that ive bought off of...........Chris Brown, yes he has a name :p and probably leave my adjustable dampers on there aswell if zeemers are as crap as everyone says they are! thats grims idea so i cant take credit for it.
Guest Battery Bill
Well it wont be any worse than with just the Zeemers :rolleyes: :rolleyes:
It couldnt be really :lol: :lol:
No actually For some people the rear Zimmers worked fine, I think Sir Chris used his for a long time before getting his wallet out :D
I had RH supplied coilovers on my 2b sliding pillock, they were "pre zimmer" & had two springs on them to beef them up (they were a monroe unit).
Problem was that the double springing still wasn't hard enough & the damping couldn't cope... Then someone (Bob Tucker I think) suggested fitting a standard set as well... so I did. Result rock hard rear end, over damped (on compression mainly) & made the back end pretty twitchy, much less controllable on track would really "snap"
I'm not saying it won't work for you (especially as yours are adjustable), just be careful....
Dan :)
I see, its only my idea when it doesnt work HUH? B)
BTW my rear springs (ex. standard rear Sierra) also hit the driveshaft, but I managed to relocate the spring tops in a different position in the cups, and repositioned the bottoms in the arms, gave me about 1/2 inch clearance which has remained fixed over 14k miles
Bob
