Acceration
Guest Takumi
Guest cjbailey
Yeah, but a pain if u use the car on the road. The system has to be disconnected and purged as well (apparently) otherwise mr policeman will have a bit of fun with you (well, depending on how switched on they are!
Admittedly the likelyhood of anyone noticing is slim, but still!
  • Replies 68
CJ,
Various publications have stated that NOS is a perfectly legal road tuning solution, as long as your car has one of those small green compressed gas labels ;)
If they really wanted you to do that, don't you think they'd have had a crack down on it by now? :huh:
Morty
Nitrous is road legal and safe. With a progressive controller on the Nitrous you can inject different quantities at different revs eg 30% at 3000rpm and 100% at 4500rpm. That way it reduces wheelspin and Nitrous consumption.
I'll do it when i've recond the engine and got some £££.
Bond: "Nitrous oxide on a Hood? You're joking!"
Q: "I never joke about my work double-oh-seven."
Andy
I found this page that calculates the torque needed to get you from 0-60 in a specified time:
http://www.peter-burgess.com/maths.html#
You need to know weight of car in lbs.
For an 800kg car it would take 215lb/ft torque to get you to 60 in 4.99s (theoretically). Just need to calculate what that would be in BHP.
Horsepower = torque(lb/ft) * rpm
5252
Someone correct me if i'm wrong.
Andy
Sounds resonable Andy,
And once you've decided on the torque output, all you then need to account for is the drag - the drag coefficient of the 7 type shape is bleedin hooooooj, :angry: and some sort of traction enhancing system to get the power down :p
Morty
Why do you think that Nitrous is illegal on the road.?? your a fool... :lol: :blink:
MG cars are selling there new SuperCar with a nitrous option.. for <1000hp
the only disadvantage of using a nitrous systems everyday, is that it costs ££ to refill.
get with it poeple...
tak
Hi All,
Not shure what your insurance co would make of fitting a nos kit :o , because you WOULD tell them wouldnt you!!! :blink:
Just make sure it doesnt spring a leak, it wouldnt look good being pulled by the fuz and not being able to stop laughing :D
Insureers dont like performance modifications to cars, unless they're a specialist in high performance cars..
Does anyone know where I can Insure my new
Koenig prepared Murcielago Twin Turbo ??
at 850hp I dont think my no-claims bonus will help much...
back to the nitrous subject:
last year at the Exeter show there was a black 2B fitted with a cosworth engine with turbo and nitrous :o .
the lad who owned/built it was from bristol i think and the car drew a bigger crowd than the ultima which was there too B)
he did tell me about the car but all i can remember was me thinking "your out of your box!!" :blink:
can anyone shead any light on this car if it is still in one piece :huh:
Holbay/Coltec Racing Engines are now playing with my Inj head, when It comes back it will have 10.2:1 cr, and 3 angle valve seats..
And on the way is a stg2 autoSprint Cam, 270deg, 11.9mm lift :)
thats all I can afford at the mo.
2000cc 205 Block
Shortened Sump / Pickup
Earl's 10 row / 200ml oil cooler
Drilled/lightened Cam/Timing wheels
2000cc Inj Head (unleaded seats)
Gas flowed
3 angle valve seats - Coltec/Holbay Racing Engines
10.2:1 compression - Coltec/Holbay Racing Engines
AutoSprint 270deg, 11.9mm lift - Stage II cam
New pad followers
Re-Profiled In/valves to grp1 profile, all valves polished
Weber 32mm/36mm DGV carb
Std Ford Carb manifold
Sports Pan Cake filter 8"x2.5"
obvious things like new filter, belts, gaskets..
This engines is hopfuly going to make around 130hp on this carb, maybe more,
upto 140hp on a DGS 38mm carb.
(Edited by Mat, Please don't pimp items on here unless you are a Member)
