Valve Clearances
Guest tom2b
I need to redo the clearances on my engine after rebuilding it. I have got the old pinto escort rs2000 engine with a kent 285 cam in it. Does anyone know what valve clearances i need and do you have any tips?
Standard Pinto valve clearances (cold)
Inlet- 0.008in (0.20mm)
Exhaust- 0.010in (0.25mm)
Do you mean Piper cam 285 :rolleyes: as kent cams don't do a 285 cam for the Pinto.
If so its a Ultimate road OHCBP285
Valve clearances for the are the same as above
Or have a look here
Piper Cams
Its defiantely a 285 cam, im sure it was a kent cam, will have to check it. I can work in old money its ok!
Ill do them before fitting my carbs as it was a pig last time with the twin choke carb fitted.
