Car For Sale On Ebay
swan
Both Tim & Enforcer are right.
What I meant but worded badly is:
a. It's unfair for anyone to "expect" Enforcer to take this on just because he's a cop. Why should he? Any of us could report it to relevant authorities.
b. It's unfair on Warwick for this to get preferential attention with the authorities (if Enforcer decided to take it on as a pet project) just because he happens to be on here. Equally Enforcer could follow his "civic" duty & submit it to the correct authorities in the same as anyone else but not take advantage of his position to escalate it.
Personally I am not in a position to do anything. If some people want to take this to the authorities then that's fine, but there must be a correct & legal procedure to follow.
I would suggest that if any police involvement it should be with the local police force not Enforcer living hundreds of miles away.
Yes, I agree it would be very unfair to a potential buyer who didn't understand what they were getting. Just in case anyone doesn't know, it's possible to send a message to the people who are bidding on something through Ebay without the seller knowing..... I have quietly tipped off a couple of people in my time who were being ripped off. Some are grateful, some think you are interfering & just trying to make them pull out. ;)
Dan :)
  • Replies 128
Thanks Derek, Dan
Any investigation into this (assuming there would be one) would be at the hands of Devon & Cornwall Police, DVLA and the relevant Local Authority - no question of me having any involvement.
Rhocar is my place of R&R ^_^ ..... certainly not looking at taking on a 'pet project' other than finishing the carpeting in the 2B ;)
$3350
thats the bid at moment reserve not met
warwick have a concience!!!!!!!!!!!!!
this bidder does not know the history of the lightweight or the FAULTS with the design.
you have not to my knowladge carried out any of the mods to streagthen the bodyshell
you are passing a problem on to an unsuspecting purchacer!
this is clearly not a lotus 7 built to modern standards
this is a con!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
you must have read the responces from the members ?
you are WRONG.
remove the sale and retain your integrety
your reality and ours must be different if you believe what you have put in your advert is correct
i am proud to have been the owner of a lightweight
my car is NOT a lotus 7.
however it is having an SVA tomorrow.
if it fails i will fix it. not sell it to a punter who knows knothing of the history
rant over
my e mail is avaiable as is my address should wish to contact me
regards graham
Graham
Appealing to his conscience is a non-starter. He hasn't even been curious enough to check this thread for over 3 days.
I wish you the very best of luck with your SVA tomorrow. Pass or fail you will know that you have approached this in the proper way.
I suspect this car will sell; it is up to £3600 now; when it sells the bidder ID will be made public and whoever the poor sod is will be inundated with messages.
Let's hope Warwick thinks his 'Lotus' is worth a £10,000 reserve ;)
WHEN PRODUCED:
September 1968 to January 1970. Series Three Page
~ Original Specifications ~
CHASSIS NUMBER SEQUENCE:
SB2311 to SB2649. The 13 Twin-Cam SS cars had the chassis number prefix 'SC'. Left hand drive cars had the prefix 'LSB'.
NUMBERS PRODUCED:
Approximately 340 at Hethel, Near Norwich, Norfolk.
CHASSIS:
Multi tubular space frame chassis by Universal Radiator Company and Arch Motors with aluminium transmission tunnel and floor acting as stressed members. Engine and gearbox rubber mounted. Transmission tunnel supports gearbox mounting.
BODY:
Aluminium clad body with self-colour g.r.p. nose and wings in Red, Green and Yellow by various contractors. Other colours at extra cost. Front wings 'clamshell' type.
FRONT SUSPENSION:
Independant by transverse wishbones incorporation anti-rollbar. Springing by combined coilspring damper units reacting through a single attachment point at each end. (Dampers by Armstrong.)
REAR SUSPENSION:
Proprietary 'live' rear axle located by a pair of trailing arms [upper] and a triangulated 'A' bracket with apex picking up beneath the axle casing [lower]. Springing by combined coilspring damper units. (Dampers by Armstrong.)
STANDARD ENGINES AND GEARBOXES:
Available to January 1970 - 1600cc. FORD 2255E CROSSFLOW overhead valve engine with Weber 32DFM twin choke progressive down-draught carburettor in standard Ford Motor Company tune developing 84bhp at 5,500rpm. Coopers air cleaner. Compression ratio 9.0:1. Gearbox, remote and gearknob as for 116E engine. Also available at the same time although very rare in a Seven - similar 1300cc. unit developing 72bhp at 5,500rpm.
Available from January 1969 - LOTUS HOLBAY CFR 1600 engine, a tuned version of the Ford 2255E (above) with twin Weber 40DCOE2 side-draught Webers developing 120bhp. Compression ratio not stated. Gearbox and remote as for 116E engine, gearknob Lotus 'ball' with black badge.
Available from October 1969 - 1558cc. LOTUS TWIN-CAM engine with twin 40DCOE Weber carburettors either in standard 'Special Equipment' tune (115bhp) or as the Lotus-Holbay version (125bhp). Gearbox as before but with uprated second gear.
REAR AXLE:
'Live' rear axle from the Ford Escort Mexico with modified Lotus casing. Standard ratios 3.77:1 for 1600cc. engine and 4.12:1 for 1300cc. engine. Options 3.9:1 ratio and limited slip differential.
BRAKES:
Front are Girling (Triumph Spitfire) hydraulically operated 9" disc type to all models. Rear are Girling hydraulically operated leading and trailing shoe cast-iron drum type of 7" dia. x 1 1/4". Mechanical handbrake by horizontal lever.
STEERING:
Triumph Herald lightweight rack and pinion steering gear, universal jointed column and 14" diameter black PVC covered 3-spoke aluminium steering wheel.
WHEELS & TYRES:
5 1/2" x 13" diameter well-based bolt on steel rims with chromium plated hub-caps. 13" light alloy bolt-on rims (Brand Lotus) at extra cost. All with radial ply tyres as standard.
ELECTRICS: (Now NEGATIVE EARTH system)
12 volt 39 amp/hr battery located on left hand side of bulkhead. Either Lucas L516 side lamps and seperate front indicators or Lucas L1130 side/flasher lamps, Lucas S700 7" double dipping headlamps with Lucas 7002 or GEC 6012 sealed beam units, Thorpe PT 675 combined rear and stop lights, Lucas L539 rear flashers. Lucas twin windscreen wipers. High frequency horn. Instrument lighting. [Extract from a Lucas Catalogue]
INSTRUMENTS:
AC shrouded Ammeter and Fuel Guage and Smiths combined Oil Pressure and Water Temperature Guage, 120mph Speedometer and 8,000rpm Tachometer. Sometimes all instruments were Smiths.
TRIM:
Black pile carpets with matching weatherproof trim and black PVC ventilated seat squabs and back rest.
MISCELLANEOUS:
Heater. 8 gallon Fuel Tank with filler point in rear body panel.
EX-WORKS PRICES (from factory ephemera):
Circa 1968/9 - Seven (Ford 225E 1300cc & 1600cc powered) - £775.00
EXTRAS:
On All Models: Four Branch Exhaust Downpipe, Close Ratio Gearbox, Engine Tuning Equipment, Light Alloy Wheels (Dunlop?), Optional Paint Specification, Roll Over Bar, Seat Belts, Oil Cooler, Tonneau Cover, Heater, 3.9:1 Axle Ratio, Limited Slip Differential.
DIMENSIONS:
Wheelbase 7' - 5", Front Track 4' - 1", Rear Track 4' - 4", Overall Length 10' - 11 1/2", Overall Width 4' - 7", Height to top of screen 3' - 3 1/2", Ground Clearance 6".
WEIGHTS:
None given in Owner's Manual. However road tests give the following:-
Autosport 1969 - Lotus Seven "S" - 1204lbs.
Autocar 29/1/70 - Lotus 7 Twin-Cam SS - 1254lbs.
Road & Track Oct 1970 - Lotus 7 Twin-Cam SS - 1210lbs,
Multi tubular space frame chassis mmmmmm its a bit different to warwicks
richard
we as a group have done i think all we can do we are not a legal entity and comment is all we can make.
i as have others have tried to prick warwicks concience.
it has failed!!!!!!!!!!!!!!!!!!!
if the purchacer askes for help i will give it frealy
the prob comes as you should know when the purchacer has a problem ie accident ect
and the insurance refusise to cough up .
or worse someone is killed
Now £3750 and "The seller has lowered the reserve price" !!!!!!! :unsure:
I have sent Warwick a PM and have urged him once again to stop this now. Ebay do not seem concerned, or haven't actioned a number of messages that I know have been sent. Warwick has not been on the site for four days now, so may not get my message. :unsure:
Graham has his lightweight SVA today and I wish him the very best of luck. ;) I have a good feeling that he will get through. I appealed to Warwick to withdraw the car from auction and get it SVA'd. If he wants to leave it registered as a Lotus, so be it (although I don't think we've heard the end of that). At least he would know that the car he sold was safe.
It's not too late to end this Warwick. :huh:
Guest Handlebars
I notice there's no highest bidder named. Just Bidder 17. So you can't even direct the prospective buyers to the threads here and locost sites. Coincidence?
My JBA is registered 1988. The MOT says ist registered 1971. Is it worth trying to get free tax?
This is a recent change by ebay to safeguard bidders identities. Nothing sinister about that, happens on all high value auctions now (and all car auctions I think).
Steve
