Granada Rear Subframe
I am thinking of building another kit and was considering a 24V Cosworth Granada as part donor. Does anyone know if the rear diff / subframe is the same as the sierra?
Cheers, Boggie
Hey Boggie
Theres an "Echo" in here!
Look four posts down in the Donor section.
Bill
The Granada rear wheels are 50mm further apart than the Sierra, the drive shafts are each 25mm longer so I expect (I don't know for sure) that the mountings are different for the de-deon tube.
Granny's also need bigger mushrooms/dummy strut inserts. Come standard with ABS too so may need to scavenge a Sierra too.
Thanks Guys,
Looks like I need a Sierra too! Does anyone know which model (if any) has a 3.6:1 LSD?
Boggie
