Size Of A Lightweight
Guest cherno
Guest cherno
Happy new year.
In advace thanks for your forum and sorry for my english ( I'm a frenchy ).
I Can't find indications about the size of a ligthweight :
Wheelbase, width, weight, can it fit on a small trailer who support in total only 750Kg. What is the best way to tow it with another car.
There is a load of info if you search... I think finished weight is in the 650kg+ range.
A few of the guys should be able to give you the wheelbase etc.
You could tow with a trailer (likely to need a braked one as it will top 750kg incl the trailer weight) or you could fit some kind of hinged A frame with a towing eye to the front of the chassis. This needs A LOT of careful thought with a lightweight though, the monocoque aluminium chassis is not ideal for this (easy on a 2b). I'll be doing this to mine at some stage as you just sneak under the 750kg towing limit.
Dan :)
hi
you will need a braked trailer capable of taking about 650 to 720kg depending on the engine type that is fitted.
dont chance it it ant worth it.
width on the rear is roughly the same as a sierra, front slightly smaller.
regards graham
Guest cherno
I've found these dimension for a 2B
DIMENSIONS AND WEIGHT
Length: 3500mm
Width: 1700mm
Height: 1180mm
Wheelbase: 2480mm
Track:
front: 1460mm
rear: 1480mm
Ground clearance: 120mm
Are the same for a ligthweight
Guest ScotMac
Wheelbase: 91.25"
Length: 125" (from rear of chassis to front of chassis - no nose cone)
Track: Front will be different than 2b, but rear should be exactly the same
Front: 52" (w/ i believe 35mm offset 15" wheels)
Rear: hub flange to hub flange: 56"
Width:
Cockpit: 42" (designed to match locost)
Weight: Gonna be highly variable based on the build (engine, drivetrain components, strengthening, ...). *Somewhere* between 1000 -1400lbs.
Guest cherno
Wheelbase: 91.25"
Front: 52" (w/ i believe 35mm offset wheels)
Width:
To resume ( I have to convert because I have no way to measure pouces ).
Wheelbase : 2.31m
Length : 3.17m
Track
Front: 1.32m
Rear: 1.42
With
cockpit: 1.06m
Thanks for that.
I live in south of France near Montpellier.
Cherno,
Have you bought a lightweight already? If not steer clear in my opinion (will prob only find part builds now) & buy the new Zero instead. It has a proper chassis & will make a good track car.
Are you going for a bike Engine?
Dan :)
Guest ScotMac
Cherno,
Dan :)
Dan is correct that the Zero is probably a better choice. The lightweight can give you a nice result, but requires quite a bit of your own fabrication to handle the strengthening of the base monocoque, as i mentioned earlier.
Besides, we like the exclusivity of the current set of l/w owners! ;)
Guest DoLittle52
Recently, I purchased one of the partial kits from "Jim" at Coveland Motorsports in upstate New York, USA. Partial kit means that you do not receive the instructions and you do receive lots of excuses. Then once Coveland gets tried of making excuses communications just stop altogether.
The kit is a great deal like a complicated jigsaw puzzle with major pieces missing and all of the supplied peices unidentified.
Guest ScotMac
Chuck, did you see my reply to the thread you started about your lightweight?
