Rhocar Racing Barkston Heath 30th August
Guest John Walton
  • Replies 74
For anyone not seen the circuit before.....
Anyone care to point out the entrance on here? I think it's off of Heath Lane at the bottom but can't be sure....
As I recollect. the entrance is by the buildings at the top of the lane (where the B6403 sign is), I think you ignore the first sign to Barkston Heath (assuming you are heading towards ancaster) and turn left into a small gatehouse, if you need fuel carry on past the gatehouse turn off and go left at the traffic lights, the petrol station is a couple of hundred yards on the left.
Just follow the people with big grins on their faces.
Tom Hayden
Guest old_timbo
Looks like it will be hot! Think I'll try running without bonnet and screen this time. Under bonnet temps got so high last time, my nose cone distorted in the area over the radiator :(
Guest John Walton
Local trafic info' from the RAF boys. Be aware and look for other routes as required
The A1 will be closed between the A47 junction at Wansford and the A43 at Stamford from 6pm on Saturday 30 Aug 08 to midday on Sunday 31 Aug 08, while a new bridge deck for the junction improvement at Carpenter's Lodge is lifted into place. Diversions will be via the A43 and A47.
The 650-tonne bridge deck will be moved by a special vehicle and lifted into position on to the already constructed and prepared bridge supports
:huh:
what happened to Nigel?
from a run 1, 54:9 to a run 2, 1:06:3 ?
did he stop to whip the engine out and put it back ;)
cheers
ek B)
just realised, that must have been the lubrication incident
Guest Busterandcharlie
Pic of the list of times and final standing.
Should have realised I can't insert pics in events :huh:
Les
Can we make a spec list of the different cars.
It would be interesting to compare different engine / tyres combinations
No. 29 & 129 is a standard 2l pinto lump with bike carbs (never set up or rolling roaded) on very cheap hard wearing road tires
Edited by Busterandcharlie
Guest tez_hall
for driver 10 and 101
not good time of 1:05sh
got a 1800pinto (reconned)
standard production ford carb
tyres were cheapo 185/85/14
also the rear suspension is in need of some serious upgrading... to get rid of sqeak if nothing else
im going to fit some gaz shocks over the winter
and i have some 205/15 wheels...
may try and find a cheap carb replacement until i can afford twin dellartos or webbers
be interested if that will imrove times at all for next time
over all we both enjoyed the day and was glad there were no serious casualties
thanks to john for organising it all
tez
I agree with Dan.... :D
Bob
Spec is Redtop, (untouched with 100K miles on it!!) twin 45 Dellortoes,
Sliding pillars replaced by RSJigtec wishbones, Gaz shocks on the front, AVOs on the rear
TOYO 888s all round.....back ones nearly bald after Barkston!!
