Zetec Differences?
Guest info@trackdayUK
Hi,im about to buy a 2.0 zetec lump for my Hood and wondered what are the differences between zetec engines ie silver top,black top and any other sort of tops!!!!
cheers
liam
There are several:
  • different size sumps, although they will both fit, the silvertop is shorter,
  • different water pumps, both in rotation and fit, important for fitting of alternator,
  • alternator usually on ,the other side due to the above,
  • flywheel size
The silvertops can also have their cams changed to the blacktops giving a few more bhp
regards
Ian
There are several:
  • flywheel size
regards
Ian
cool,so a silvertop with blacktop cams has how much bhp compared to a straight blacktop??
The blacktop is the better engine with a little more potential although both are disappointing IMO. Head flows slightly better as standard and has shimmed mechanical cam followers. Silvertop has hydraulic followers. Have to switch them to mechanical if fitting above a 285 profile cam. Cams are different profiles. I believe the heads will swap but why would you?
Nothing is interchangeable in the blocks which are different internally and externally. They use different oil pumps, water pumps, cam belt layout and tensioners, rods and pistons. All flywheels swap OK. Don't know about cranks. The two piece blacktop sump will not go on silvertop due to its taller main bearing caps fouling the cast in windage tray dividers (the dividers could be ground down) but silvertop sump will go on blacktop. Silvertop sump is one piece cast ally and the windage plate is tin, held on the engine by extended 2 & 4 main bearing cap bolts. Silvertop sumps come in different depths with those off an escort being shortest.
I can't see any reason for fitting silvertop except pre 95 engine for easier SVA admissions. The blacktop is the better engine.
stay with the st
the info is on the way
poss by post as we cant unload it
graham
oh alright then if the info is coming ill wade through it and see if im up to the job!!
how much hassle getting it onto a type9 box??
