Bike Carb Help
Guest james123
Guest james123
Hi all need some help with setting up my fireblade bike carbs. I have 1.8 pinto with standard mechanical pump which seems to be overfueling the carbs and leaking like a goodun. The original demo zero had this set up and was running fine any suggestions? I know alot of people use different pumps but was trying to get away with it. Is balancing them something i can do easily also it isnt idling and just cuts out where can i adjust this? alot of questions i know thanks james
Guest marsbar
Hi the mechanical pump has too much PSI, a bike electric fuel pump at 2-3 PSI is what you need, you can use your mechnical one but have to buy a facet pressure regulator which will be dearer than the £30/£40 that of a bike pump.
As other people comment you will get better and more detailed advice.
