Prop To Diff Fixings
Guest jeffszero
Guest jeffszero
hi all ,wondered if anyone could shed some light on a problem i have ,i have a diff(supplied by GBS)3.92 ratio,and a modified prop (also suppled by GBS) the prop does not line up with the diff ,or two out of the 4 holes do but the other 2 are about 1/4inch out,have i been supplied a diff for a 2ltr and a prop for a 1.6 ?for info the gearbox is a MT75.
thanks in advance
jeff
Hi Jeff just try turning the prop till it lines up with the next hole round .
Bernie
As Bernie says the holes ar'nt in a square just turn the prop until they line up
Guest jeffszero
Bernie
hi bernie
thanks for the reply,i can line up 2 hole diagonally but the other 2 dont line up .but i will try again now i have calmed down a bit :mellow:
will let you know how it goes ,thanks again .
Guest jeffszero
thanks for the reply i have to admit i thought the hole were in a square ,i will go and try again :blush:
thanks again guys i knew the answer would be on here
Guest jeffszero
sorry guys didnt know the holes wernt in a square config :blush: i will try again .i knew the answer would be available on here
