Power Upgrade
Guest Tim Norman
Guest Tim Norman
Whilst telling the "work Boss" of the impending upgrade, he already thinks I'm barking, he mention "Keyman Insurance" for when I disaapear in a cloud of flames and twisted metal! So I figured I'd better have a look aat the brakes as well so I now have on order a set of vented grooved and cross drilled Mintex C-Tech Brake Disks and a set of Mintex M1144 Grade Pads to go with them. So, the weekend following the Tan Hill trip I will be starting the upgrade. I hope to have it all on and wired up over the weekend. The list below is everything I have, Am I missing something?
Emerald ECU and loom and MAP sensors
VR Sensor sheilded cable and bracket
Trigger wheel
8 nr 54mm dia throttle bodies
Pair of manifolds
Water rail
Inlet manifold gasket and new set of bolts
Velocity Stacks
Brake discs
Brake pads
High pressure fuel pump
Swirl pot
Fuel hose
Custom Magnecor leads
2 nr Edis Units
Switch to allow map switching on the fly
Big set of nads!
Screw loose
I'm not expecting huge increase in power but more flexibility and a smoother response.
When it is all on and has been tuned, the current induction and ignition systen will be up for grabs.
  • Replies 99
Guest woolly
i thought you were missing the coil packs.
the ecu will fire them unless it needs the edis units aswell. unfortunatly the leads may not fit. :(
bin wrong before :(
sounds fun
enjoy
Guest dinger
Yeah, you will need a coil pack and leads,
oh, and maybe a new pair of pants. He He.
Good luck with the upgrade and will look forward to the updates
