Clutch Cable
Guest davy h
Guest davy h
hi does anyone know the best way to shortern clutch cable and the best way of fixing it to a clevis pin
i have seen a cable clevis at demon tweeks with a screw to hold cable,will this be a strong enough fixing for a clutch or would a soldered end be required
Guest dinger
Speedy cables can make you up a cable but that does carry a price, the way you have mentioned is perfectly ok and is the way I have done mine,
Although being an RAC patrol with a clutch cable repair kit does help,
Have you get a link for the clevis, may be the same as the one I have used,
Guest gixerboy600
Alternatively you could buy the custom length one available from GBS??
John
