Spanky Lives Again
chris n
Old Spanky is all sorted and up and running again with a new cam belt and oil seals :D after her mishap at the weekend
It looks like a stone or some other foreign body has at some point got in between the auxiliary shaft and auxiliary pulley damaging the oil seal causing oil to leak out over the cam belt, even with a cam belt cover fitted to the engine. :shok:
How much Oil was she using? Not as much as John Peach I bet.
I :wub: my :rhsc:
Wasn't using that much oil. I think the leak from the oil seal looked worse than it did as the auxiliary pulley had sprayed a good coating of oil over the crank shaft timing cover.
:lol: Would never use as much oil as Smokey in her prime :p
