Side Lights
nigelt
Guest garyfelton
Front side lights are a requirement, usually on a 2B they are fitted into the headlight unit. You will need units with a provision for the side light and a fixing to keep the bulb in place. Typical fixings that can be used are from old mini's MG's etc..
HTH Gary
As per the previous post - If you're using the standard sealed-beam units that come with the kit, there should be a clear section near the connector pins, where your side light shines through. You can buy a sub-loom with side light provision for about £8, or the Robin Hood way was to wire in the bulb and just leave it dangling in roughly the right place. :rolleyes:
My link
