My Zero
Guest gdc
  • Replies 62
Probably won't pass IVA -- edges are too sharp; take a look at CBS cat, IVA soft edge & E marked for only £2.40 a pair (does not say pair but that's what you get) :unsure:
I see what you say, but the ones you actually get are exactly the same as CBS et al. like this.
dan has added some more pics .
we have very litle work at the mo so been busy in the shed ,
the nose hase been on and shaped waiting for edge trim now to fit,
both the rear wings fitted and finished .
front end,1 wing and bonnett to fit.
clean up ex manifold and paint and wrap , buy new ex and fit .
then it will run ,
we hope .
graham
hi al
not running as yet .
i need some carbon fibre as a heat sheild to go behind the ex , cos i think the
vinyle will get melted ,
so holding off on fitting the ex as yet .
i spoke to phill tonight and he says yours is coming on .
dad
hi steve thanks for the praise,
re the slots ,gbs sell a small rubber edge trim, but it needs gluing on, i just stuck the back
down so it didnt damage the surface on the front of the seat ,
graham
the ex manifold has been sent to gbs ,qwerty was there today and he says it has arrived , they are going to make a cat and a silencer to suit the car ,
when that is fitted i can get the car rolling roaded and fully set up
after that just the dreaded test, shaft advised me not to fit carbon as a heat shield
so i have made some panals to go over the vinyl, edge trimmed and sprayed with ht paint
hope it works we will see .
graham
so i picked up the new ex and silencer at the open day .
ordered new standard st injectors , they arrived from germany today .
installed in mins and pressed the button ,
its alive !the st is running in the zero .the omex 600 has paul c/s map thanks paul and runs better than it ever did before , after the week i have had this is a real lift .
the person that mapped it before reconed i needed saab terbo injectors , i went along with that but it was never right , this even though pauls engine has a vernier and mine has not is better .
i will run it tomorrow and check water oil ect , then book it into troy at n/hampton motor sports for a r/r sesion .
after that it needs a test . then plates .
graham
ps crap week , but a great lift .
Must get the vernier. Makes a ton of difference. Exhaust cam uses the standard blacktop/silvertop vernier. (Confirmed by piper). Paul has the other of a pair I bought from the states. I'm currently running 6degrees of advance or retard (can't remember which!) and it makes a big difference. Can run 8. Just need a mate with a ST170 who will go halves on a pair.
