Window Wipers
Guest Kennedy48
Guest Kennedy48
Just trying to sort out the window wipers. There off position is on the pasenger side. So we are having trouble getting the wipe to extend over the drivers side. How far is enough?
Luke
Guest AWhite
I bought some wipers that bend the opposite way (i think from Europa - can't really remember) Now they park on the drivers side and the driver gets the full wipe and passenger get half a wipe. Figured the driver was more important. :)
Andy
Some do one each way so that the wipers park in the middle and wipe to each side leaving the un-cleared part behing the rear-view mirror. I've also seen a setup with three small wipers across the width of the screen.
Iain
Guest Kennedy48
Cool thanks everyone. Il look into the wiper arms but il see if I can turn the motor around first. I didn't want to take too much apart as I'm finished.
luke
Guest AWhite
You can just get the wiper arms that face the other way. No need to change the motor around. If they auto park just need to make sure they park in the right place. Mine don't so I just do it manually by turning them off when they get to the right point.
Andy
To get them to park on the other side you don't need to move the motor just turn the spindle boxes through 180 degrees. if you just turn one you get the "clap hands system" as described by Iain
Guest gdc
easy answer is dont fit till after iva , install all the hardware and electrics then remove as little as poss
cover the bits that show and iva .
graham
