Bottom Ball Joint
Guest Boost
I have just got some old sierra hubs, now need the ball joint to fit before I make the wishbones, I have seen 2 options
  1. Cortina
  2. Maxi
Can anyone tell me if they will both fit or not?
Part numbers would be good too.
Thanks in advance.
When I made our wish bones I used these, http://www.ebay.co.u...=item461acaf76c nice and simple to fit if you are fabricating your own wish bones, just need a 6mm plate with 4 holes in them .
Ball joints just bolt to the wish bone, like me nice and simple.
ignore the "ooopppps" moment with the dummy strut , cured by using some 3mm roll pins, but this is the best pic I have showing the bottom ball joint.
HTHs
Surprisingly Astra MK 2 bottom ball joints work too.
The taper fits the sierra hub 100%, and the three well spread bolt holes
allow easy fitment to a DIY wishbone.
First line FBJ5093
Ive just replaced mine with...
http://www.amazon.co...t/dp/B00ELMCS8K
HTH Bob
