Ignition Barrel Removal
Guest red lilly
Guest red lilly
Hi all, I'm wanting to fit a new ignition barrel in my new dashboard,
Is it possible to do away with the original Sierra one?
I had the idea that i could just get an angle grinder and cut it off as close as possible to the steering column,
Is this possible to do, and has anyone else done it?
I can't see any reason why I can't,
But I've been wrong before.
Cheers Ivan
Check IVA manual--- think there is still a requirement for a steering lock ( or other means of security) other than just a key switching off the ignition. Is the existing lock U/S ?
Edited by florin metal works
spelling miss-take
You can remove the barrel and then you can slide off the lock mechanism. Can't remember if its just a bolt or if you have to drill it out. You could then chop some bits off (only alloy) or just remove the part that locks the column. But i think you would have to put it back on to hold the switch gear.
what are you trying to achieve? just a clean look around the column?
