Pinto 2.0 .38 Dgas Carbs Lowered Sump
Guest ddhmlk
Lowered sump has nothing to do with power
38DGAS is a V6 carb good for 150bhp if jetted right but you need more than a standard pinto
Injection head will get 110 ish, more compression and an FR32 closer to 130
A carb only supply's the fuel an engine requires
It does not give extra bhp
I am willing to bet that no two 2B's are built exactly alike. So performance figures are unpredictable (and irrelevant in my opinion) so drive the car and if you like the way it runs, stick with it. It can get expensive chasing bhp. No idea what Betty puts out but she has torque that would rival a diesel.
The Pinto is easy to tune to 130bhp
Injection head is a key starting point
Thinner gasket for a little more compression
Camshaft and vernier pulley
Rolling road setup
I have a couple of injection heads and some tricks you can use
For higher BHP there is a noticeable cost increase as you will need big inlets, multiple carbs
More compression and probably stronger or reworked rods
The next step is Forged Pistons and steel rods
OUCH £500 for pistons £300 for rods
The injection head is the same as a standard head except it has better inlet port flow worth 10 to 15bhp
You'll need a head gasket set but use a Rienze gasket as its thinner
You'll need to replace head bolts
If you don't know how old the cambelt is change that
What I do is to amass the bits I need over a period of time that way the pain feel a lot less
