Pinto Dizzy
lockyer89
Shot type motorola or?
Peter2b
? what you mean? ,its a 2 wire to normal coil just like an Accuspark unit , probably from same factory ,small unamed module , push on sleeve to centre shaft for switching mick :crazy:
What mower man is saying is it has its own electronic module inside it and just two wires to connect up. No external electronic module needed. If its a lumenition magnetronic style one then the two wires just go to the + and - connections on the coil. Very simple and reliable. Snap it up.
