Fitting Gauges
tractor
What resistance are you getting on the signal wire at the sender end to the chassis ground (disconnect meter for now to measure this)
I was reading ~ 4 ohms when empty going to ~ 140 ohms when full. So if you take the signal out from the meter and put it through a resistor to the chassis between these two figures, you should see some sort of reading on the dial. It may be a slow response if the meter is damped. At least you can measure the sender and test the gauge separately this way.
Simon.
