Type 9
jaimo
Topped up gearbox pit in just over 1 litre so that was issue a lot quieter now
Hi, you managed to get a whole litre of oil into your gearbox! I have the same gearbox - with no issues. I've never managed to get to the refill plug to top up, and never applied a concerted effort so I've never checked it. It's in a monocoque chassis too. Your topic has encouraged me to look at this more seriously. So, did you use the filler plug, if so how did you get to it? If not, what cunning method did you use?
Old cats pee. Mixed with rats poo.
Awful stuff.
Absolut must use if recommended. Without ep, bronze or brass bearings will just wear out as if using sand paper.
Don't forget to grease the seal face though or it will burn on 1st use and start leaking again!!
Quoted because taking your engine and box out again for a flippin oil seal is a waste of a weekend. :aggressive:
Didn't manage to remove mine with just a screwdriver, I used a centre punch to deform the metal frame inwards first, before flicking it out.
Edited by Grim
