Exmo Revamp
jaimo
well gonna update as i go with this but starting with engine picked this lot up from keith and chris
205 block with .5 oversize pistons in mint nick etc so once collected the engine stand from ian on with the rebuild will update with pics as i go
I wouldn't! Use at least 8.8 rated bolts to mount. B&Q threaded bar is recycled tin cans and not reliable to support a pinto.
You can get two bolts into the top two bellhousing mount holes and two more with nuts into the bellhousing mount holes at 3 and 9 o'clock.
Please don't use B&Q bar.
Screwfix sell variable quality. Threads and lengths.
Look in online catalogue and get part number before you go.
As stated earlier, 8.8 or equivalent.
Good luck with your rebuild mate.
  • 4 weeks later...
Got the bolts to fit block to stand and valve stem oil seals and also got a good injection head for bargain £40 pick that up tomorrow hopefully get to start rebuild soon
Edited by jaimo
