Windscreen Wiper Blades
alanrichey
Guest jelleyhead
You can get replacement blades from central auto supplies which is now known as motor parts direct i got a pack from there you get two blades i can't remember how long they were but you just cut them to size you need if you can't get any i mite be able to get you some and post them to you hope this helps
I have Caterham S3 arms and blades pre bent. It's as if they were made for it! Had them off eBay £15 pair of arms inc. Wipers. Nothing to adjust out of box straight on car. Most parts fit off the S3 and are good quality.
I originally used long ones that were chopped so looked like yours. But then i created my own 'blade' wipers from long ones. Had to re-weld a return for the fitting on the wiper arm but now they clip on and off like normal ones.
work pretty well when i've been caught out in a few heavy downpours. Made a spare which is easy to swap on if needed as you don't have to unscrew etc.
