Need New Lift Pump Suggestions
Guest david_l_perry
Guest david_l_perry
Following on from my failed fuel pump thread....., I need to buy a new one. Bit lost on what to go for as the original was out of a Mitsubishi I think, Inlet and outlet on one end.
I have a spare high pressure pump, but would rather use a Low pressure pump as I understand that's the better option for a lift pump
No idea what to go for, any ideas or links for a low pressure pump. Ideally a round case rather than the square facet pump, as it will fit in my existing bracket with little modification.
Dave
Facet type are very good.
Buy a decent quality part.
Remove the gauze filter from them before use.
They block to quickly, to easily. You stated you had good filters already.
You should have some idea of you mpg so double that output using letters per hour using average speed.
Too much is better than not enough and has no adverse effects.
Fit it below bottom level of tank for best results. That way it should never dry out and spoil.
Guest david_l_perry
Ordered a proper facet pump. Lots of 'facet style' on evil bay for around £12, but don't want to mess around with cheap fuel pump. Proper facet posi-flow ordered £26 Still not big bucks.
Ta
