Weber Dcoe Part
Guest clive5550
Guest clive5550
Hi all bit of a long shot I know but if you don't ask and all that...... has anyone got the castellated ring that sits on top of the carb on a weber dcoe under the jet inspection cover thanks Clive.
If nobody comes up with the goods, you might try the guy I use, advertises on eBay. Just type in weber and open up a couple of ads and you will find him. The trading name is fast road cars and the service is very good with most stuff arriving in a couple of days. Reminds me I need some manifold studs.
Guest clive5550
Hi, no its not number 4 apparently after a bit of research it's off a weber dcoe 40 type 34 they are a old carb and the part is no longer available so not sure how I'm going to get it sorted thanks Clive.
Guest clive5550
Hi thanks Bob I've tried both of those and Webcon,fast road cars, and carburettor specialist.com all with the same answer that the part is no longer available i just wondered if someone had got an old carb somewhere as I say if you don't ask but it seems as though it's going to be plan b whatever that is ! Thanks
