Exmo
jaimo
The exhaust heat has melted mine away and it's part !missing and part crusty can remodel it but would of been quicker if could just put new one on that's all and an exhaust that points away from it
Might not be any use to you as I don't know if you could mod them to fit.
Two Haynes rear wing on fleabay under kit car parts.
Don't know number as I was just glancing through the other night.
HTH matey.
Item 162182571877 is one of them. Look around for a matching one for you.
Edit. Have a look on the same page under similar items. Nice powerful engine for you. RS pinto.
Edit 2. Just looked at engine and for some reason the cam belt has been removed. Bit iffy is that mate.
I would bang a belt and starter on it before I paid for it and do compression test.
Edit 3. Item 122073310574. Good looking and favourable price.
252489418840. Mega expensive from GBS. Depends how much you want to spend but I would go for 122073310574. All you have to do then is paint them yellow or, find fronts to match.
Good luck with your project matey.
EDIT 4. As Cris would say, talking done so get on with it.
Edited by 2b cruising
