Speedo Not Working
Guest Rikos
Disconnect cable from speedo head and check that the inner rotates when you drive. If it does then the speedo is faulty if it doesn't then the cable has broken or the outer has come loose. If you need to change the cable then depending on the car you could cut a hole in the gearbox tunnel to help gain access.
