Indicator Stalk Problem
Matt brown
I have a s7 With Sierra steering colum and the hazard switch has broken and won't turn off, I have also broken my lights stalk while removing the dash piece, is there any way of changing the stalks on both sides with a universal type setup as it's proving difficult to find a replacement for the hazard side stalk.
http://www.carbuildersolutions.com/uk/multi-stalk-assembly
I found this but was unsure if I could make it work would anyone be able to shed some light on this or suggest a different option. Thanks
You could use an early Transit stalk, there are 2 problems with it though, physically it will bolt straight on, but the stalk is quiet a bit longer than the Sierra one. Also the electrical connection has flat pins instead of round ones, so you'd need to acquire that plug with a few inches of loom from a scrap transit to patch into your own loom.I was just about to go this way when mine went knackered, but I managed to get the sierra one just in time.
I think this is the genuine one that you're needing http://www.ebay.co.uk/itm/BNIB-Early-Ford-Sierra-Indicator-Switch-arm-very-rare-/322385229446?hash=item4b0fa83686:g:-z4AAOSw4GVYHf3M this one has the horn button as well.
Or is it this one of these ? http://www.ebay.co.uk/itm/FORD-SIERRA-MK1-XR4i-XR4X4-3-DOOR-COSWORTH-INDICATOR-STALK-SWITCH-KIT-CAR-/182419423257?hash=item2a790b8019:g:jzUAAOSw5cNYd6LC This one doesn't have the horn button
http://www.ebay.co.uk/itm/SIERRA-SAPPHIRE-INDICATOR-SWITCH-/272522967381?hash=item3f73a27955:g:US8AAOSw2xRYe6~k
Light switch stalks. http://www.ebay.co.uk/itm/SIERRA-SAPPHIRE-WIPER-AND-LIGHT-SWITCH-STALK-GENUINE-FREE-POSTAGE-1989-/171324563352?hash=item27e3bd5f98:g:l4YAAOxy3NBSeSS6
And another set. http://www.ebay.co.uk/itm/FORD-SIERRA-MK1-XR4i-XR4X4-3-DOOR-COSWORTH-LIGHT-WIPER-STALK-SWITCH-KIT-CAR-/302190314647?hash=item465bf24497:g:USMAAOSwo4pYcYUR
And another (cheaper at moment) http://www.ebay.co.uk/itm/FORD-SIERRA-WIPER-LIGHT-SWITCH-/391677843615?hash=item5b31d1989f:g:GKcAAOSwhdRYWZm~
And just to show you, The early Ford Transit indicator switch. http://www.ebay.co.uk/itm/FORD-TRANSIT-1991-2000-STEERING-COLUMN-INDICATOR-STALK-SWITCH-91VB13B302AG-NEW-/162186730670?fits=Car+Make%3AFord%7CModel%3ATransit&hash=item25c3151cae:g:JLwAAOSwAuZX19x-
Edited by Big Jim
Lets see some photo's of your switches. This is the problem, Ford changed things all the time, also RH used what-ever he could get hold of, so different cars might have different stalks. you could even have Escort ones.
You can use the Escort Mk 2, this is a better stalk as it also has the horn switch built in, by a small mod you can then have the horn button next to the steering wheel, I picked one up for a few quid last year
