Pinto Problem
jaimo
The diesel was to check leak test when head was off it took couple of hours to soak away so gaps cant be that big
I have put the accuspark plugs in so can you gap these
Look at this on eBay http://www.ebay.co.uk/itm/181661171042
All sparking getting fuel
Going to try new battery later
But its not even trying just turning
Regardless of the low compression, if the engine is slow to turn have you checked the starter motor. A knackered starter motor will drain the battery and give similar symtoms as you've described.
If you have fuel and spark and its turning.. then you need to makre sure its at the correct place.
is the engine timed up correctly with marks..
is the spark in the correct place..
I have a strobe light you can borrow
Edited by maccavvy
Those plug caused me real grief if the head has been skimmed a lot they get spark gap shut by piston contact! mick
You won't get piston to plug contact unless the head has been skimmed 2mm
1.5mm if Pistons are flush to block
Check you engine block earths if starter slow
Feel the power lead to the starter, if that's got your Earth is not good
Well just fully charged battery only took an hour (strange)
Then boosted with anorther fully charged battery and still nothing not even trying just turning over
Think going to recheck compression etc again tomorow after work
