Pinto Gaskets
cb750
Ebay item 232496018418. Anyone used these "high performance" foam on steel gaskets, are they any better than the Victor Reinz ones that I normally use?
Also has anyone any experience of the half moon rear sump seal with the extended ears? Does away with the cork wedges and supposed to give a better seal.
The cork wedges need a spot of sealant before you push them in.
Where the main bearing carriers meet the block is a line where oil seeps out, its this attention to detail that will give you an oil leak free engine
Thanks both. I've never had a problem with the standard type gaskets, I was wondering why they have developed the foam on metal gaskets and the change in shape for the rear curved rubber seal. I thought that the original wedge system woul be easier to seal than this later piece (the red seal) with the extended ears.
