Sign in to follow this
jaimo
Premier Wiring
Has any got some diagrams that they made or any instructions or tips etc for premier wiring pinto loom
As got one and trying to alter slightly and cant understand a fews bits such as in rear loom the fuel pump wire where does feed in loom/fuse come from and where best to take power from for drls ignition live and megajolt coil pack etc also ignition
Also changing fuseboxes to bigger ones
Also how and where do i connect output from alternator to starter solinoid to battery
Help
Edited by jaimo
Share this post
Link to post
Alternator must not be connected to the solenoid --- it's connected to the starter feed cable which comes direct from the battery --- but you probably meant that.
Share this post
Link to post
i have a diagram somewhere will try and find it
Share this post
Link to post
i also got rid of the pwl fusebox and fitted the cbs fuse board and relay module
Share this post
Link to post
Yeah bob i meant that cable but join at starter end thats correct isnt it
Chris any diagrams etc brill
Edited by jaimo
Share this post
Link to post
couldnt find mine so had to copy this from locostbuilders
Share this post
Link to post
when i fitted the CBS fuse relay board i realised that all i would be keeping intact from the premier wiring loom was the rear loom the CBS wiring module makes a rewire so easy although i did end up adding a couple of extra 8way fuse boxes so actually some circuits have two fuses in them
Edited by tractor
Share this post
Link to post
Thanks chris i will hopefully beable to sort it from there but then again
Share this post
Link to post
