Sign in to follow this
kevin booth
Help With Noise On Motorhome
I have a problem with my motorhome that i am having trouble identifying.
When i take up drive from a standing start and change gear i get a single knock from front offside, sounds to me like its a C/V joint but they are only 2000 miles old. Both side C/V joints feel like they have the same amount of play in them.
Any ideas welcomed as not sure where to look now
Share this post
Link to post
Bushes in suspension arms/wishbones, gearbox or engine mounts, possibly ball joint. What make and model? Can you repeat the knocking noise by engaging clutch and releasing last minute and re-engaging like rocking the camper van?
Share this post
Link to post
Talbot express Kontiki.
Does it every time i pull off or change fron 1st to 2nd. Cannot get it to do it sat on the drive
Share this post
Link to post
Engine Mounts are a particular weak point on those. Check them
Share this post
Link to post
Posted quickly yesterday - Now found some evidence. I changed mine and made big difference. Worth changing for the cost as they are weak point.
https://talbotoc.com/change-your-rear-engine-mount-t4143.html
Also you can get then from here.
https://www.jktowers.co.uk/Engine_Mountings/cat1473101_1336537.aspx
Share this post
Link to post
Checked all mount and they look new. Think i have found it, looks like os cv joint. When turned i can replicate the noise. ( will remove and check joint and splines plus hub ) Thanks for all the replies Kev
Share this post
Link to post
