Davo
Fuel Gauge Troubles
We have to leave on Saturday now, no fixed time to leave, so all flexible.
I'll try & persuade her indoors....
Share this post
Link to post
Got wires crossed here I think Bob T, the Bob I was posting to was Newbie Bob.
Will be great if you can make it over as well, Bob T along with Bob N & Bob F --- that's 3 Bob = 15 pence
Edited by florin metal works
Share this post
Link to post
Turns out the advice about not removing the sender unit if at all possible was sound. As predicted Im having trouble sealing it. Any advice?
Share this post
Link to post
Follow advice in 17 -- !!! OR repeat with new gasket & petrol proof GOO.
Share this post
Link to post
To seal the tank well I made up a C ring (pic below) in 4mm steel plate with bolts welded through it to match the sender/tank holes. This can be inserted inside the tank and will pull up to sandwich the thin tank top and gasket between itself and the sender. Getting the cut-out in the C big enough to allow it to be fiddled into the tank but small enough to not loose sealing was the only difficult part.
Pic below is rough idea that I used with the filler. Same style for the sender.
Share this post
Link to post
All attempts so far have failed so Ive just ordered that o ring. Making the clamp I imagine will be more challenging though. Ill let you Know how it goes.
Share this post
Link to post
Thanks Peter. All received.
It fits the sender perfectly. Ive just used washers and nuts for the minute until I can build a brace. Ill hopefully be able to take it for a spin over the weekend.
Share this post
Link to post
