Guest Patt
I would imagine it needs a gasket if the old one had it. You could probably make your own if you can get some gasket material. Used to be available in the good old days.
As for my post above i think i might have been thinking of the entire MC and servo from the KA being remotely mounted. The pinto has the exhaust on the drivers side so the servo fits in the space. With a zetec with injection the inlet is too close to the pedal box so you have to mount the servo the otherside if you want a servo. Well this is from memory of reading bits and pieces so might be talking nonsense.
sounds like you are nearly sorted though. hope it all works again soon.
