Sign in to follow this
PumaPower
Sigma RWD conversion
I'm currently swapping out my mighty xflow in favour of a 1.7 Z-SE, but keeping the trusty rocket box, although my problem would be the same if I was changing to a type 9.
I have an issue with the size of the input shaft and the spigot bearing hole in the crank.
RWD Motorsport do a bearing that will fit, but that requires the input shaft being ground down to 10mm and I'm struggling with getting that done locally.
Anyone here had this issue and found a solution?
Share this post
Link to post
I can't recommend any company form experience, but a quick search on google and I would say start with these guys - http://www.specialisedengines.co.uk/ - if they cant do it, I would say it is likely they could recommend someone who can.
EDIT:  See Bob Tuckers post below - Seems this company is best avoided!
Edited by theduck
Share this post
Link to post
Assuming you're happy to remove the input shaft yourself, it should be fairly easy to find an engineering firm who would turn down the input shaft end for you... a fairly routine job for anyone with a suitable lathe/workholding (assuming the input shaft isn't anything too weird and wonderful). I can think of loads in the Midlands area, plus one in Derbyshire, that I am on talking terms with but you really want someone local you can just pop in to. I would start looking on google maps/business directories for engineering firms local to you - target the typical light-industrial business parks of which I'm sure you have loads. With a bit of ringing-around and some friendly visits-in-person by yourself, I suspect you'll find some machine shop that'll do it out-of-hours for you, for £20 in the hand of the operator who does it ;)
A lot of kit building and jobs like this rely on you building up a reparté with small businesses. Never underestimate the power of walking into a place unannounced and having a polite, friendly chat with the guy on the front desk. "Alright mate? Listen, I dunno whether you can help me with this little problem, I'm trying to find somewhere that would do..."
...and away you go ;). Rememeber the phrase "No I don't need a VAT receipt" :D
Share this post
Link to post
Ditch the needle roller bearing and use a plain olilite bearing. I think you need 17mm O/D and 1/2" I/D so it should be easy enough to buy one of these and get the centre bored out and the O/D turned down to size.
https://www.bearingboys.co.uk/?catid=1158&display=&orderby=&att1=12mm&att2=18mm&att3=
Share this post
Link to post
From personal experience
DONT GO ANYWHERE NEAR SPECIALISED ENGINES
Also check Dave Andrews site for another unbiased opinion.
& Google "specialised engines reviews"
If you dont mind a trip to "the Dark Side!" I can thoroughly recommend Dartford Rebore.....small family run business.
http://www.dartfordreboreenginecentre.co.uk/
Edited by Bob Tucker
  • Thanks 1
Share this post
Link to post
