front indicator problems
stevedohc2b
HI
my son has a Golf Plus Mk 5 one of the front indicators is intermittently not working
Wont flash when un locking car all others do
will sometimes flash when hazards on
will not flash when indicating right
 put hazards on will flash then will work when turning
I have swapped bulbs cleaned all terminals and contacts in lamp holder and with contact cleaner on big multi plug on headlight assembly
checked all fueses
Help
Stephen
The switching signal is very low  0.4 to 0.6 volts mm set on up to 20 v
tried a new earth lead from side of bulb holder to body started to flash then stopped removed from body and seamed ok
 now still not working again  have 2 new headlights on order as both very cloddy hope that fixes it it is all ecu controled not a relay
 hope this fixes it will know on Tuesday
stephen
Can you give more details of the car. Year, engine, model. I can have a good look at the wiring diagrams.
After a quick look at the basic Mk5Golf+ the earthing of indicator bulb is shared with the main beam and side light bulb from the 10 pin plug on the headlight, back into the car loom.
Thus if side and main beam lamps work normaly that rules out earth from plug to car.
There is the two black wires within the headlamp unit which go from plug pin9 to the ind bulb and back to pin7 which you need to look at. These could be faulty at either end.
If OK then you need to look at supply from the onboard supply control unit under the dash, and it shouldn't be hard to check the wire from that to the headlamp plug.
I can get more info if needed. My wiring diags are for left hand drive vehicles so some side to side swaps of numbers/connectors/pins might be needed or guessed. (For instance front window motors are reversed but door locks are not)
Edited by Longboarder
