Sign in to follow this
Ophidr
Zetec help
I am just putting together my new zetec engine which way around does the spiget bearing go and is it best to fit before i put on my clutch plate
Share this post
Link to post
Fit spigot bearing first. Is it a needle roller or a plain bush? Normally it doesn't matter which way round.
Share this post
Link to post
Usually needle roller and there is a tiny lip seal in it. Gently taps in with a 'same size' socket and the seal is last in. The seal should be nearest the gearbox, not nearest the crank but that's only if you have OCD. Probably doesn't matter.
Edited by Longboarder
Share this post
Link to post
Brilliant how far do i need to tap this in does it matter
Share this post
Link to post
Flush with the hole is fitted in should be fine.
Share this post
Link to post
Flush with the rear face of the crank, not all the way to the bottom of the hole in the crank.
Share this post
Link to post
Between the engine and the type 9 gear box do you use the thin shim plate
Share this post
Link to post
Yes you do but it's primary purpose is not as a shim but to stop debris getting inside the bellhousing so sometimes called a crud plate. You can adapt the one from the pinto as shown below.
Share this post
Link to post
