Sign in to follow this
RevKev
Sierra / Escort brake calliper refurb
Hoping I can tap into the knowledge base of the RHOcar community
So I''m doing a refurb the front brake callipers of my Robin Hood 2B which when I brought it I understood to be based on a Ford Sierra 2.0l GLSi manufactured Dec 1988.  Needless to say the brake refurb kit I got has the wrong size pistons (they're too big).  The callipers on my 2b have a 54 mm piston which seems to suggest they are Escort callipers.  Where the callipers interchangeable between Escort and Sierra? Is it possible that Escort callipers are on the front end of my 2B or did some Sierras have a 54 mm piston?
All I'm looking to do is order the right refurb kit!
Any advice is gratefully received
Kevin
Edited by RevKev
Share this post
Link to post
Have you got solid or vented discs and have you got discs on the back? Front calipers can be 53mm on 1.3, 1.6 and 2.0 cars without rear discs. Cars with rear discs have 60mm calipers.
https://brakeparts.co.uk/shop/Ford/Sierra
More specifically this for 1988 2.0
https://brakeparts.co.uk/shop/Ford/Sierra/82-89/Sierra 2.0 OHC Models/Front - Brake Calipers and Wheel Cylinders
a choice of 2 depending on rear brake setup.
Edited by richyb66
Share this post
Link to post
Hi
Once again indebted to your greater wisdom!!! Thank you!
After much searching I've managed to find a refurb kit for the 54mm callipers.  And yes... drums on the rear
Kevin
Share this post
Link to post
