Spark plugs
MarkBzero
I have just started to play with nitrous and for higher powered jets I need to retard the ignition and fit colder spark plugs with 3 earth pins.
Always fitted OEM parts so how do I find colder spark plugs with 3 earth pins for ST170 engine?
1 hour ago, theduck said:
Not sure why the need for 3 earth pins?
From what I can see the standard plug for st170 is NGK PLTR6A-10G and the upgrade plug is NGK ILTR6A-13G
The instructions suggest a single earth pin can get very hot and cause pre-ignition, 3 pin earth spreads the heat and less likely to cause ignition prematurely.
Would have thought heat would be more of an issue in boosted setups than in a nitrous setup. Doesn’t the nitrous have a cooling effect? Might be worth seeing if you can speak to any of the drag racing guys who run nitrous, see if the 3 pronged plug thing is a common recommendation.
22 hours ago, theduck said:
If you are using copper plugs rather than fancy platinum etc, then in the NGK range just go for the next number up, so as an example a standard pinto plug is APR6FS but the next step colder is APR7FS
I thought it was the other way round, the larger the number the hotter the plug, so a 7 is hotter than a 6, but happy to be wrong
Edit I'm wrong I'll go stand in the corner
https://www.ngkntk.in/ngk-technology/importance-of-heat-range/
Edited by phaeton
