Zetec coil pack plug extension
nelmo
I'm getting a repeat of my misfire problems and I'm pretty sure it's my coil pack plug that is the culprit again. My problem is that I made the engine loom and I annoyingly made the wire to the coil pack only JUST long enough to get to the coil pack - it basically needs some extra length because I think the vibrations are jiggling the plug too much, causing my misfire.
So I really need a way to add some length which I'd like to do with an extra male/female coil pack plug. In the diagram below, the top is what I have at the moment, the bottom is what I need. The tricky bit is that male coil plug - I don't know if something like that exists (can't find anything online)
Anyone have any ideas if I can get that male plug? Or other ideas of how to extend my wiring - I'd rather not cut the existing loom and add wires in manually - my soldering is rubbish (but that is plan B).
