front wings
max
Which bit are you concerned with? How the brackets fit to the uprights or how the wings fit to the brackets?
Brackets to uprights varies depending on what uprights your car has
Wings to brackets people normally either bond or bolt or both
yes how the brackets are fitted to the rear of the wheel
I assume yours is a sierra based monocoque with inboard shocks?  In which case the brackets would normally be welded to the dummy strut.
yes will look at making the brackets off the dummy strut
