Vicky Green More Help
Guest olly
help needed if any 1 has any now how on the vicky green loom and could help me would you call me on 07742784070 AND I WILL RING YOU RIGHT BACK so its my bill not yours
its driveing me nuts
thanx loads peeps
olly :wub: :wub: :wub: :boohoo: :blink:
  • Replies 41
amend your profile to show where you are as there may be someone local to you who is willing to help. If you are in the north west there will be lots providing you keep the kettle on :p :p
its a b2 cos you have a 2b we cant live on the same street and have the same car next door to each other
tell ya what tho the vicky green witll be on ebay very soon im off to the scrapy for some proper wires
What is actually the problem you're having Steve? don't just say "The wiring" we can't help with an "all encompassing" statement like that. lets do an individual area at a time.
If it's the control stalks, then the problem isn't caused with the loom, but with Uncle Henry keep changing his mind, as there are a number of different stalks, all wired up individually.
big jim
iv not got any probs with all the lights horn indicaters reverse switch fog lamp there easy its the clocks i have a few weres that have got me stumped and the wiper side and indicater side switches just dont seam to way up
heres what i have on my cluster for the clocks
pin 1 to 13
1/brown and white
2/brown
3/brown and yellow
4/2xblue
5/black and gray
6/black and white
7/not used
8/brown and green
9/black and yellow
10/white and blue
11/brown and black
12/2xgreen
132xgray and green
is that ok for now or do you want the rest?
thanx loads
olly
On the site somewhere is the wiring details for the instrument cluster...its right for 95% of the sierra intruments...
However, mine is different (typical) :p
I made my own wiring and I have the pin outs for the intruments if the main board is wrong in your case as well...
Dave
PS Jim's been drinking again! He called Olly Steve :unsure:
Guest TerryBarry
Hi Steve,
This is where it gets interesting :rolleyes:
I've got the Sierra Panel - Part No. is 87BB-10848-DA (on rear of cluster, just above the speedo).
The flexible printed circuit only has 12 connections to the harness plug
These are as follows
Pin #
1 - Blue / White = Main Beam
2 - Black / Yellow = +12v from IGN switch
3 - Brown / Green= Oil Pressure
4 - Black / White = Indicators
5 - Green = Tachometer
6 - Brown / White = Temp Gauge
7 - Brown / Black = Fuel Gauge
8 - Black / Green = Indicators
9 - Brown / Yellow = Brake Warning
10- Blue = Alternator Warning
11- Brown = Earth
12- Green / Slate = Illumination
1 to 12 (Right to Left) Viewed from rear of Panel
My wiring connections ( from the Sierra) do not agree with those given in the Haynes manual (# 0903) - the donor was a 1989 2.0 GL Hatchback
