Steering wheel/air bag removal
Davy
Which model, normally there are a couple of bolts which you get at from behind, then you lift the airbag away to undo the electrical connection, then a big nut in the middle of the wheel which needs to be loosened, then leaving the nut on you rag the wheel towards you, sometimes a little left & right movement helps. Leave the nut on the shaft just in case if comes off a bit quick & you get a faceful of wheel, once it's loose undo the nut fully & remove the wheel. This is not particularly specific to MX5 but covers most Japanese cars.
