August 25, 20206 yr I think my Starter motor is on its way out or it is not powerful enough to turn engine over. I was going to replace it with a high torque starter motor. I do not know what type of gearbox I have joined onto my 2.0 Pinto? How do I find out which I have? Thanks Tony
August 25, 20206 yr Looking at your car and the age of it I would say it has a type 9 gearbox fitted. Check if the Bell housing and gearbox are cast iron in looks if so then it is a type 9. The MT 75 is aluminimium.
August 25, 20206 yr type 9 reverse is down, left & forward. MT75 is different, IIRC down, right, back.
August 25, 20206 yr Have a go at re-furbing the starter solenoid first, a lot of poor output problems of starters is down to the main contacts being burnt/pitted. There is a good write up of solenoid re-build in this month's CKC mag.
