September 2, 20206 yr Does anyone know the correct torque settings for a 1984, 1993 Pinto head. I have tried the net and had various options.
September 2, 20206 yr From my Haynes Manual Cylinder Head Bolts Splined type bolts Nm lbf Stage 1.............................................................................40 to 45 30 to 41 Stage 2.............................................................................50 to 70 37 to 52 Stage 3 (after 20 minutes)................................................ 73 to 83 54 to 61 Stage 4 (after running engine for 15 min at 1000 rpm)......95 to 115 70 to 85 Torx type bolts Stage 1..............................................................................35 to 40 26 to 30 Stage 2..............................................................................70 to 75 52 to 55 Stage 3 (after 5 minutes)..................................................Tighten through a further 90 deg.
September 2, 20206 yr Sounds right Maca, must say the 90 degree final tighten on the Torx bolts made me cringe a little but worked fine on my 1990 Pinto. Probably telling you what you already know but make sure the bolt holes are free of any fluid and I would suggest to use clean engine oil on the threads of the new bolts..
