2b upper balljoint change bolt access issue
Hello,
I'm having to change the upper balljoints in the mushrooms due to knackered boots and they seem quite loose, however I was amazed to find the bolt inside canted over at such an angle that I can't see how I'm supposed to even get a socket in there! how are people managing this???
Thanks, Scott.
Link to post
If I remember correctly (it was over 15 years ago) when I built mine I had to use the shortest socket I had from a cheap set I bought when I was a teenager.
HTH
Nick
Link to post
Solved the issue, I chopped a 19mm 1/2 inch drive and 13mm 3/8 drive sockets in half. Welded them together and then ground a 3/8 extension into a wobbly one.
Worked perfectly nut off in a few seconds, one for the toolbox smile.gif cheers for the suggestions
Edited by Scott MacNab
Link to post
